Does Aruba have access points with more than 2 ports rather than AP103H?
  • 1.  Does Aruba have access points with more than 2 ports rather than AP103H?
    Posted Sep 11, 2014 12:16 PM
    I need AP with 2 ports ethernet ?
  • 2.  RE: Does Aruba have access points with more than 2 ports rather than AP103H?
    Posted Sep 11, 2014 12:21 PM
    The 103H is your only option.
  • 3.  RE: Does Aruba have access points with more than 2 ports rather than AP103H?
    Posted Sep 11, 2014 12:27 PM
    Can I deploy it outdoors like on small shop?
  • 4.  RE: Does Aruba have access points with more than 2 ports rather than AP103H?
    Posted Sep 11, 2014 12:28 PM
    You could put it in an enclosure, but it is not designed for outdoor coverage.
  • 5.  RE: Does Aruba have access points with more than 2 ports rather than AP103H?
    Posted Sep 11, 2014 11:06 PM
    I assume this is for downlinks to other devices? If you can tolerate a single VLAN and 100Mbps, maybe check with your rep as to whether a 225 using .11at power can handle one of those little 5-port 10/100 USB-powered switches.  Not that any of that is designed for outdoors either.
  • 6.  RE: Does Aruba have access points with more than 2 ports rather than AP103H?
    Posted Sep 12, 2014 12:19 AM
    Another access ponits you can use
    RAP155
    It has 4 ethernet ports, and it has option for 2 of them being poe..
    That AP is indoor so dont use it outdoor...
    Cheers
    Carlos
