Does Aruba Instant AP need license like PEF-NG and so on?
  • 1.  Does Aruba Instant AP need license like PEF-NG and so on?
    Posted Jun 17, 2014 08:48 AM
    When deploying IAP do we need licenses ?
  • 2.  RE: Does Aruba Instant AP need license like PEF-NG and so on?
    Posted Jun 17, 2014 08:49 AM
    No.
    The only licenses for Instant are:
    Aruba Central - cloud management licensed by AP
    AirWave - on-prem management licensed by AP
    Controller PEF-V - licensed by controller for advanced IAP-VPN deployments (RBAC)
    None of these are required for IAP functionality.
  • 3.  RE: Does Aruba Instant AP need license like PEF-NG and so on?
    Posted Jun 17, 2014 09:14 AM
    I can't find PEV-V for Instant ! kindly advice
  • 4.  RE: Does Aruba Instant AP need license like PEF-NG and so on?
    Posted Jun 17, 2014 09:16 AM
    It's not a required license. You only need this for the IAP-VPN architecture if you are doing advanced role-based access. (It is a controller license)
  • 5.  RE: Does Aruba Instant AP need license like PEF-NG and so on?
    Posted Jun 17, 2014 09:18 AM
    So you mean I can use RBAC with instant without any license?
  • 6.  RE: Does Aruba Instant AP need license like PEF-NG and so on?
    Posted Jun 17, 2014 09:31 AM
    Yes, you can.
  • 7.  RE: Does Aruba Instant AP need license like PEF-NG and so on?
    Posted Jun 17, 2014 09:32 AM
    Thanks Guys I really got it
  • 8.  RE: Does Aruba Instant AP need license like PEF-NG and so on?
    Posted Aug 06, 2019 06:04 AM
    Hi guys, I am trying to configure role base access but it is not woking.
    This is a guest WLAN using inernal captive portal. As in the attached screenshots, I configured a role asignment rules so that if username begins with "t", it will be mapped to a certain role.
    But when we test, all users are mapped to the default role, including those who begins with t.
    I also noticed a strange behaviour, that when I click on the "security" tap then move to the "access" tap , the role asignment rules disapears totally! (attached the second screenshot"
  • 9.  RE: Does Aruba Instant AP need license like PEF-NG and so on?
    Posted Aug 06, 2019 10:30 AM
    Hi guys, it finally worked, I read in another community post that role based will only work with external authentication server.
    I did confgured a RAIDIUS server instead of the internal server, configured my RADIUS server to return the attribute "user-name" as success reply, then on the IAP confgured a role asignment rule to match on a specifc username and asign the needed role to it.
  • 10.  RE: Does Aruba Instant AP need license like PEF-NG and so on?
    Posted Jun 17, 2014 09:24 AM
    Yes. RBAC is built into the instant platform and can be used without anything additional. The PEF-V license is for controllers and is only needed in certain scenarios to create a tunnel between an IAP cluster and a controller.
