Does Aruba InstantOS 6.4 support EAP-SIM and EAP-FAST
  • 1.  Does Aruba InstantOS 6.4 support EAP-SIM and EAP-FAST
    Posted Sep 13, 2014 05:35 AM
    Hi Team,
    Good afternoon.
    I would like to check if the Aruba Instant OS 6.4 support EAP-SIM and EAP-Fast Authentication.
    I am trying to provide IAP-205 to one of our customers but he has a requirement that authentication should support EAP-SIM and EAP-FAST.
    I have checked the pdf doc below but could not find the answer:
    http://community.arubanetworks.com/aruba/attachments/aruba/IAP/6915/1/Aruba%20Instant%206.4.0.2-4.1%20User%20Guide.pdf
    Please advise.
    Thanks and Regards,
    Ricardo
  • 2.  RE: Does Aruba InstantOS 6.4 support EAP-SIM and EAP-FAST
    Posted Sep 13, 2014 08:43 AM
    Instant is EAP agnostic so if your RADIUS server is compatible, then you can use it.
  • 3.  RE: Does Aruba InstantOS 6.4 support EAP-SIM and EAP-FAST
    Posted Sep 22, 2014 02:59 AM
    Hi Tim,
    Good afternoon.
    Sorry for the late reply. Thanks for the information. Really helped a lot!
    Ricardo
