Does Aruba support point to multipoint GRE tunnel setup?
  • 1.  Does Aruba support point to multipoint GRE tunnel setup?
    Posted Jan 30, 2019 11:14 AM
    Just curious if Aruba supports  point to multipoint GRE tunnel setup? espcifically between a local controller and a DMZ (Hub) controller?
    Thank you,
    Rafi
  • 2.  RE: Does Aruba support point to multipoint GRE tunnel setup?
    Posted Feb 11, 2019 01:10 AM
    would MultiZone be a suitable option for sending to a DMZ?
  • 3.  RE: Does Aruba support point to multipoint GRE tunnel setup?
    Posted Feb 11, 2019 02:53 AM
    The only "multipoint" GRE from an AP standpoint happens in two scenarios:
    • AOS8 with Clustering
    • AOS8 with MultiZone
    In these two scenarios, the APs will build multiple GRE tunnels to multiple controllers.
    In the case of clustering, it is an Active/Standby User Anchor Controller  (UAC) tunnel. This is handled automatically by the clustering mechanism.
    To separate user traffic into a DMZ, Multizone would be the way to go to
    Check out the following two videos as a starting point:
    https://www.youtube.com/watch?v=tnw-JI6AnWA
    https://community.arubanetworks.com/t5/Video/What-is-MultiZone/ta-p/298349
    Please note, that for both deployments you need AOS8 with the Aruba Mobility Master.
