Does Aruba Support Port Isolation and how to do it?
  • 1.  Does Aruba Support Port Isolation and how to do it?
    Posted Jun 08, 2014 11:59 AM
    How can I achive Port Isolation to connect many users on the same SSID and each one on specific VLAN
  • 2.  RE: Does Aruba Support Port Isolation and how to do it?
    Posted Jun 08, 2014 12:01 PM
    You can’t assign individual VLANs to every user automatically, but you can enable “Deny inter-user bridging” which will stop wireless clients from being able to communicate with each other.
    Sent from Surface Pro
  • 3.  RE: Does Aruba Support Port Isolation and how to do it?
    Posted Jun 08, 2014 05:03 PM
    Couldn't you do it with derivation?
  • 4.  RE: Does Aruba Support Port Isolation and how to do it?
    Posted Jun 08, 2014 06:03 PM
    I'm sure there's some way you could rig it up with your RADIUS server, but it'd be a hassle.  The trick would be getting the RADIUS server to respond with a unique VLAN for each user that connects.
    The controller performs stateful firewall inspection and it can deny inter-user traffic as Tim pointed out.  Using roles and firewall policies, there shouldn't be any need to use VLANs for separation, unless PCI compliance is necessary.
  • 5.  RE: Does Aruba Support Port Isolation and how to do it?
    Posted Jun 08, 2014 06:15 PM
    I guess the question should be: what is the use case? Are you trying to replicate cisco private VLAN?
