Does "clear os" no longer work in Instant?
  • 1.  Does "clear os" no longer work in Instant?
    Posted Jun 13, 2013 01:40 PM
    I've has three different times now since 3.3 has come out where I attempted to the clear the OS from the CLI on different APs with no luck.
    The AP boots back up with the old config.
    Has this changed?
    > clear os
    > purgeenv
    > saveenv
    >reset
  • 2.  RE: Does "clear os" no longer work in Instant?
    Posted Jun 13, 2013 01:45 PM
    Do you have it plugged in the same segment/VLAN as the other configured IAPs?
  • 3.  RE: Does "clear os" no longer work in Instant?
    Posted Jun 13, 2013 02:00 PM
    No. No existing IAPs.
    And I've had this happen recently in our lab.
  • 4.  RE: Does "clear os" no longer work in Instant?
    Posted Jun 13, 2013 02:07 PM
    You may have already tried this but just in case , check this link:
    https://arubanetworkskb.secure.force.com/pkb/articles/HowTo/R-1417
