Does Client-state sync work with captive-portal authenticated users?
  • 1.  Does Client-state sync work with captive-portal authenticated users?
    Posted May 23, 2017 10:02 AM
    Does anyone know if Client-state sync work with captive-portal authenticated users?
    In the following post, it is stated that it works for 802.1X authenticated users but nothing is mentionning other authenticated users. (https://community.arubanetworks.com/t5/Aruba-Solution-Exchange/Client-State-Sync-with-AP-Fast-Failover/ta-p/202619)
    Thank you!
    Best Regards,
    François
  • 2.  RE: Does Client-state sync work with captive-portal authenticated users?
    Posted May 23, 2017 10:18 AM
    The client sync state feature only works for 802.1x.
    What happens is that it synchronizes the OKC cache for clients to the second controller so that they can avoid the 4-way handshake upon failover. That is the extent of the client state sync feature.
  • 3.  RE: Does Client-state sync work with captive-portal authenticated users?
    Posted May 23, 2017 10:20 AM
    Hi Colin,
    Ok, make sense.
    Thank you for your answer!
    Best Regards,
    François
