on provisioning Page it is possible to set the Antenna Gain for the External Antennas. Does this Gain affect the configured Power Output on the RF Profile? Or is it only informational and its necessary to Reduce the EIRP Power manual if an external Antenna is connected.
Best Regards
@mtraettner wrote: Hello, on provisioning Page it is possible to set the Antenna Gain for the External Antennas. Does this Gain affect the configured Power Output on the RF Profile? Or is it only informational and its necessary to Reduce the EIRP Power manual if an external Antenna is connected. Best Regards
The latter.
Ok so i have to reduce the Powerlewel manul....
How is it with the internal Antennas? Is that Gain considered by the controller or must i reduce the Powerlevel also manual...
Thank you and best Regards
