Does IAP 225 supports country code IN because we tried with IN, instant ssid not visible?
  • 1.  Does IAP 225 supports country code IN because we tried with IN, instant ssid not visible?
    Posted Mar 29, 2014 01:48 AM
    We have tested with country code india, as soon as we enable country code IN, AP reboots and ssid instant not broadcasted.
    and when we selected another country code like UK, then IAP will started working,
    could some one will confirm wether IAP 225 will support in INDIA spectrum or any configuration is required,
    thanks in advance for helping !!!
    #AP225
  • 2.  RE: Does IAP 225 supports country code IN because we tried with IN, instant ssid not visible?
    Posted Mar 29, 2014 07:33 AM
    What version of IAP are you running?
  • 3.  RE: Does IAP 225 supports country code IN because we tried with IN, instant ssid not visible?
    Posted Mar 29, 2014 10:53 AM
    Check what Collin said
    And well it should support it its on the compliance list
    https://pctools.arubanetworks.com/compliance/
    Now they add countries to be supported on the firmware updates
    So let say taht in the initial AP 225 was not supported in india  and then on later firmwares they added it to the compliance list.
    So try updating to the lastest firmware to see if it doesnt go to air monitor.
    Cheers
    Carlos
  • 4.  RE: Does IAP 225 supports country code IN because we tried with IN, instant ssid not visible?
    Posted Apr 01, 2014 02:10 AM
    We are running latest Aruba OS 6.3.1.2-4.0.0.4_42384 but still facing same issue.
    kindly sugest on same.
    Satish
  • 5.  RE: Does IAP 225 supports country code IN because we tried with IN, instant ssid not visible?
    Posted Apr 02, 2014 05:36 AM
    Satish,
    Sorry for taking so long to get back to you.  IN country code is scheduled to be enabled in 4.0.0.5 for the IAP 225, which should be the next release of instant.  Let me try to find out when it will be released and get back to you.
  • 6.  RE: Does IAP 225 supports country code IN because we tried with IN, instant ssid not visible?
    Posted Apr 02, 2014 02:00 PM
    Okay.  4.0.0.5 is scheduled for release the week after next...
