Does IAP comes with OpenSSL/TLS feature?
  • 1.  Does IAP comes with OpenSSL/TLS feature?
    Posted Sep 15, 2014 10:31 PM
    Does IAP (IAP-105) comes with OpenSSL/TLS feature?
    No, right?
    Thus, it is not affected by OpenSSL vlunerabilities, right?
  • 2.  RE: Does IAP comes with OpenSSL/TLS feature?
    Posted Sep 16, 2014 05:24 AM
    It is not affected by the latest vulnerabilities.
    http://www.arubanetworks.com/support/alerts/aid-08182014.txt
  • 3.  RE: Does IAP comes with OpenSSL/TLS feature?
    Posted Sep 16, 2014 09:46 PM
    Thanks, Michael!
    Does IAP support any other form of TLS implementation (other than OpenSSL)?
  • 4.  RE: Does IAP comes with OpenSSL/TLS feature?
    Posted Sep 18, 2014 06:42 AM
    i don't believe so, to be honest i don't know any product that can just change the whole SSL implementation with a configuration flag or such.
