Does IAP support LLDP-MED?
  • 1.  Does IAP support LLDP-MED?
    Posted Aug 23, 2016 10:00 PM
    Hello, I can't seem to find a clear answer as to if IAPs support LLDP-MED to negociate PoE wattage more precisely than per device class.
    I have a customer using Cisco 802.3at switches with a limited power budget. All ports will have IAP315's and if they take the actual power needed (14.4W according to data sheet) I will be OK. If they announce themselves only as class 4 and make the switch reserve full class 4 power I won't have enough.
    I know the the IAPs now support LLDP via the "MAS Integration" feature but not sure if that includes the LLDP-MED enhancements, the manual only talks about "increasing PoE priority".
  • 2.  RE: Does IAP support LLDP-MED?
    Posted Sep 07, 2016 11:27 AM
    Yes they do support LLDP-MED. If you connect them to a switch that supports LLDP you can see the full neighbour detail of the IAP including the system name of it.
