Does IAP support named-vlans ?
  • 1.  Does IAP support named-vlans ?
    Posted Jul 27, 2014 06:10 PM
    I can't find anything in the User Guide, so I guess the answer is no, or not now.
    But do the IAPs support named-vlans?
    [Edit]  Actually, in the role can I specify a vlan assignment to be a pool of more than one.  I'll try that tomorrow.
  • 2.  RE: Does IAP support named-vlans ?
    Posted Jul 27, 2014 06:43 PM
    As you suggest, named VLANs are not supported in Instant; but you can use multiple VLAN IDs (separated by comma) for pooling multiple VLANs.
  • 3.  RE: Does IAP support named-vlans ?
    Posted Jul 28, 2014 01:37 AM
    True, I can use a pool for the ssid, but in the role if I have a vlan derivation rule, I can only specify one vlan it seems.
  • 4.  RE: Does IAP support named-vlans ?
    Posted Jul 28, 2014 11:48 AM
    Yes, if you are setting up a rule within a role, only 1 VLAN can be defined.
