Does IAP support web filtering without a central subscription??
  • 1.  Does IAP support web filtering without a central subscription??
    Posted Oct 27, 2016 07:05 AM
    Hello All, that is my question, because I understand filtering are cloud based services and I´m really confused about that. I have an IAP cluster, no central, no other subscription, customer need web filter, what he need in order to get that?
    Thanks!!!
  • 2.  RE: Does IAP support web filtering without a central subscription??
    Posted Oct 27, 2016 07:07 AM
    Yes, a WebCC license can be ordered independently of Central. WebCC and support is included with the central license.
  • 3.  RE: Does IAP support web filtering without a central subscription??
    Posted Oct 27, 2016 07:16 AM
    Thanks Tim, this means without this license / central we cannot expect to do web filter (ie, web categories filter) it is for an School.
    last question;  this is the webcc license you reffered?
    SUB1-WE-IAP-1
    1 year subscription for cloud-based Web Policy Enforcement capability for 1 AP
    thanks and B regards
  • 4.  RE: Does IAP support web filtering without a central subscription??
    Posted Oct 27, 2016 07:32 AM
    No. You would need either the license you mentioned or a Central license.
  • 5.  RE: Does IAP support web filtering without a central subscription??
    Posted Oct 27, 2016 07:55 AM
    thanks so much Tim!!
    Jorge
