Does Mesh portal also giving access in 5Ghz? While serving mesh points?
  • 1.  Does Mesh portal also giving access in 5Ghz? While serving mesh points?
    Posted Dec 11, 2014 03:44 AM
  • 2.  RE: Does Mesh portal also giving access in 5Ghz? While serving mesh points?
    Posted Dec 11, 2014 05:08 AM
    Hi Friend,
    Yes. Mesh portal still serve the clients over a radio even if we configure the a radio for the mesh link.
    End of the day ARM will take care of all these things :)
    Here is the POC :
    Hope you got clarity on this. please feel free to comeback if any further help needed on this.
  • 3.  RE: Does Mesh portal also giving access in 5Ghz? While serving mesh points?
    Posted Dec 11, 2014 02:20 PM
    I would read the Outdoor VRD to understand some of the best practices. Typically it's best practice not to serve clients on the same link as your mesh backhaul. This can cause degraded performance. If you need 5 GHz and are looking at mesh then you might want to take a look at the MSR4000 as it has 4 radios so you can do something like that.
  • 4.  RE: Does Mesh portal also giving access in 5Ghz? While serving mesh points?
    Posted Dec 13, 2014 07:55 AM
    Thanks for all the great info & answer.
    Have a lovley weekend!
