Does outdoor planner require Google Earth Pro?
  • 1.  Does outdoor planner require Google Earth Pro?
    Posted Mar 04, 2013 02:15 PM
    I'm currently playing around with the outdoor planner software.  I'm using the free version of Google Earth.  Everything works fine on the Outdoor Planning Tool, but when I get to the Calculate Data section, I get the below error.
    "Uh Oh...
    For Analysis please contact an administrator and send them a copy of the kmz file you tried to upload"
  • 2.  RE: Does outdoor planner require Google Earth Pro?
    Posted Mar 04, 2013 04:45 PM
    Hi Salvi,
    If you are using GoogleEarth for commercial purposes, then you are required to own a Pro license for GoogleEarth.
    The technical issue you ran into has nothing to do with Google Earth.  It may be either a procedural issue or a KMZ issue.
    Can you please forward the KMZ directly to me at chuck@arubanetworks.com?
    Thanks.
  • 3.  RE: Does outdoor planner require Google Earth Pro?
    Posted Mar 04, 2013 04:51 PM
    Will send you the file in a few.  I'm just testing the software so I can show it to management and a Pro license be purchased.
  • 4.  RE: Does outdoor planner require Google Earth Pro?
    Posted Mar 14, 2013 06:07 PM
    Any update on this?  Sent you the file but never received a response.  We purchased the Pro license, but it's still doing the same thing.  I have another file that was created by our support engineer and it works fine.
  • 5.  RE: Does outdoor planner require Google Earth Pro?
    Posted Mar 23, 2013 11:22 AM
    You can PM it to me, or email me at 'jhoward -at- arubanetworks -dot- com' and I can look and see if I see anything odd about it.
  • 6.  RE: Does outdoor planner require Google Earth Pro?
    Posted Apr 08, 2013 02:40 PM
    Contacted TAC, issue ended up being the naming of the AP locations on Google Earth.  The Aruba tool doesn't accept any type of -/\, etc type of characters in the names.  It doesn't provide a good description on the error message though to figure it out what the problem is.
  • 7.  RE: Does outdoor planner require Google Earth Pro?
    Posted Apr 08, 2013 11:47 PM
    You're right, the error codes are less than helpful much of the time. Good rule of thumb that I have used for years which hasn't let me down yet, is I always use lower case, no special characters outside of a '-', and keep the lengths of the names used for placemarks as short as possible. I also never put more than 30-40 placemarks per KMZ. So on my larger projects with 200-300 APs, I break them up into multiple, smaller KMZs and render separately, and then for any documentation, I will open and turn them all on. There's loads of reason why, but more than anything it keeps fast renders possible and helps the machine run smoother.
    Additionally, I usually create a folder called 'Locations' as required, but also outside of that (under the root) also keep a folder called 'Objects' that I put all non-placemark data in. Most of the time the planner mucks with the polygon overlays (usually changes a transperant color to a solid white) but that's an easy fix post-processing.
    Good luck, glad TAC got you straightened out.
