I am getting ready to update our 3200 series controllers from 6.1.3.10 to 6.1.3.11. Does the RAP firmware get updated as well next time they connect?
Yes,It will upgrade automatically and will reboot.
(using TFTP process while rebooting on, port 69udp)
Thanks, I wasnt sure if they upgraded for each release or just certain iterations
Yes,it's must be identical AOS - if not your RAP/AP will not work
