Does the Aruba SC1-48 controller support more than 48 AP's with additional licenses?
  • 1.  Does the Aruba SC1-48 controller support more than 48 AP's with additional licenses?
    Posted Feb 18, 2014 10:44 PM
  • 2.  RE: Does the Aruba SC1-48 controller support more than 48 AP's with additional licenses?
    Posted Feb 19, 2014 03:59 AM
    Yes,U can increase this to 128AP'S
    You should order:
    SC-48-C1-UG-128
    + Needed other Licenses (Based on existing Licenses)
    Be aware that SC - doesn't support AOS above Version 5.X.X
    Me.
  • 3.  RE: Does the Aruba SC1-48 controller support more than 48 AP's with additional licenses?
    Posted Feb 19, 2014 06:25 PM
    Thank for reply.
    I am facing an issue. I have 92 AP up with 128 Ap license and 128 PEF license. Currently i want to transfer the licenses to different controller but on the licensing site it show only 48 Pef-license . So if I am transfering license from old to new controller, will I be able to bring 128 AP up. I think the 128 pef license due to the upgrade from 3.x to 5.x, where the user based license converted to ( PEF = AP license). If I have to bring the 128 AP will I be able to bring them on the new controller of same model.
  • 4.  RE: Does the Aruba SC1-48 controller support more than 48 AP's with additional licenses?
    Posted Feb 19, 2014 11:00 PM
    You may want to contact TAC and log a case.
  • 5.  RE: Does the Aruba SC1-48 controller support more than 48 AP's with additional licenses?
    Posted Feb 24, 2014 07:40 PM
    Thank you for the update.
    How to check the PEF license count on the SC1 running 5.0.4.13. Do we have any command to check the count of PEF license?
    Show ap license-usage (shows the ap license)
    show license verbrose (shows the license key)
    however above output does not shows the PEF licesne count.
  • 6.  RE: Does the Aruba SC1-48 controller support more than 48 AP's with additional licenses?
    Posted Feb 24, 2014 07:49 PM
    Are you refering to user count like PEFNG? if yes then there is no user count as this is licenss for generation 1 controllers where are bind to the controller instead of users.
  • 7.  RE: Does the Aruba SC1-48 controller support more than 48 AP's with additional licenses?
    Posted Feb 24, 2014 08:08 PM
    My query is:
    If I want to up the 128 AP's on the SC1, do we need to have 128 PEF license (128 Ap license = 128 PEF license).
  • 8.  RE: Does the Aruba SC1-48 controller support more than 48 AP's with additional licenses?
    Posted Feb 24, 2014 09:37 PM
    You will need the following license:-
    LIC-SC1-PEF-UG-1 - Policy Enforcement   Firewall for Supervisor Card I (Upgrade 48 AP to 128 AP)
