does the integration between LDAP and the controller require any agent or certificate ?
  • 1.  does the integration between LDAP and the controller require any agent or certificate ?
    Posted Dec 05, 2016 09:55 AM
    does any one have clear document for integration steps from both side ?
  • 2.  RE: does the integration between LDAP and the controller require any agent or certificate ?
    Posted Dec 05, 2016 10:10 AM
    What are you using LDAP for?
  • 3.  RE: does the integration between LDAP and the controller require any agent or certificate ?
    Posted Dec 05, 2016 10:26 AM
    for users authentication . i have dot1x ssid and the authentication is from the LDAP .
  • 4.  RE: does the integration between LDAP and the controller require any agent or certificate ?
    Posted Dec 05, 2016 10:44 AM
    It is recommended to use a RADIUS server.
  • 5.  RE: does the integration between LDAP and the controller require any agent or certificate ?
    Posted Dec 05, 2016 11:21 AM
    i know , but the customer wants only the LDAP !!
  • 6.  RE: does the integration between LDAP and the controller require any agent or certificate ?
    Posted Dec 05, 2016 11:47 AM
    What authentication method are they planning to use?
  • 7.  RE: does the integration between LDAP and the controller require any agent or certificate ?
    Posted Dec 05, 2016 12:32 PM
    as i told you ssid with dot1x authentication , and the authentication server is the LDAP as it contains the users of the domain .
  • 8.  RE: does the integration between LDAP and the controller require any agent or certificate ?
    Posted Dec 05, 2016 12:55 PM
    Is your customer willing to install custom supplicants and/or configuration profiles to many client devices in order to support this configuration?
  • 9.  RE: does the integration between LDAP and the controller require any agent or certificate ?
    Posted Dec 05, 2016 01:24 PM
    i need to know what is the requirements from his side to tell him , then i will know if he is able to preapare this .
