Comware
  • 1.  Does the v1910-24G need reboot to change the ip?
    Posted Mar 18, 2013 10:31 AM
    I recently bought two v1910-24G, I am having an issue when logging into the web interface after changing the ip address of the router.
    The situation was the following:
    • Switch using public range (i.e. 123.123.123.123/24)
    • Changed the ip to 192.168.1.123/24 fro the serial console
    • I can ping the ip address, and telnet the port 80, but I don't have access
    • I can no longer login via web interface, on serial everything is working ok
    Is this a known issue? Rebooting the switch is quite slow, and I'd rather not schedule a downtime just to change the ip.
    I am on the current firmware version.
    HP Comware Platform Software
    Comware Software, Version 5.20, Release 1513P07
    Copyright (c) 2010-2013 Hewlett-Packard Development Company, L.P.
    HP V1910-24G Switch uptime is 1 week, 2 days, 22 hours, 31 minutes
     P.S. This thread has been moevd from Switching > Comware-Based to Web and Unmanaged - HP Forum Moderator
    #comware
    #managementip
    #v1910
  • 2.  RE: Does the v1910-24G need reboot to change the ip?
    Posted Mar 19, 2013 04:23 AM
    Another idea I've tried is to check for suspicious ACLs or similar in the command line interface, or if there is any method to restart the webservice for the router.
    So far the best documentation on CLI mode is this one (http://glazenbakje.wordpress.com/2012/08/21/hp-v1910-secret-commando-list-how-to-enable-it/), but doesn't list any method for doing what I intend.
  • 3.  RE: Does the v1910-24G need reboot to change the ip?
    Posted Mar 20, 2013 07:39 AM
    At the end waiting 24h was enough to get my access back. Not what I expected for a medium range switch, but it worked at the end.
