Does WPA3-Enterprise support Transition (backwards compatibility)
  • 1.  Does WPA3-Enterprise support Transition (backwards compatibility)
    Posted Sep 20, 2022 12:06 AM
    I'm looking at testing WPA-Enterprise with our devices. After reading the WPA3 Security section of the Aruba Instant User Guide, it looks like WPA3-Personal supports transition (supports WPA2 only devices) but WPA3-Enterprise doesn't. Is this correct? Can WPA3-Enterprise support Transition (supports WPA2-only devices)?
  • 2.  RE: Does WPA3-Enterprise support Transition (backwards compatibility)
    Posted Sep 21, 2022 02:05 PM
    When you configure wpa3-aes-ccm-128, wpa2 enterprise clients can connect without issues.
