Don't work CPPM redirect to external portal
  • 1.  Don't work CPPM redirect to external portal
    Posted Mar 20, 2019 10:25 AM
    ArubaOS 8.3.0.4.67604
    Controller 7030.
    Guest wlan created by task wizard.
    aaa authentication captive-portal "Test_Guest"
    server-group "Test_Guest"
    redirect-pause 1
    no logout-popup-window
    protocol-http
    login-page "http://172.16.60.250/index.html"
    welcome-page "http://172.16.60.250"
    no enable-welcome-page
    white-list "Test_guest"
    redirect-url "http://172.16.60.250/success.html"
    netdestination Test_guest
    host 172.16.60.250
    aaa profile "Test_Guest"
    initial-role "Test_Guest-guest-logon"
    max-ip ipv4 wireless 3
    radius-interim-accounting
    radius-acct-session-id-in-access
    reauth-wired-user-vlan-change
    enforce-dhcp
    172.16.60.250 - it's radius and web-portal server (centos).
    if user after connect manual enter in browser url: http://172.16.60.250 - he see login page, and after enter login-pass in cppm page - user may use internet, auth success.
    But auto-redirect on portal "http://172.16.60.250/ - not work.
    Why? Where are i have error in rdr-cfg?
  • 2.  RE: Don't work CPPM redirect to external portal
    MVP EXPERT
    Posted Mar 20, 2019 10:35 AM
    Does your inital role "Test_Guest-guest-logon" contain the captiveportal ACL? Is your client also assigned a valid and working DNS server? Have you also replaced the default cert on the controller?
  • 3.  RE: Don't work CPPM redirect to external portal
    Posted Mar 20, 2019 10:42 AM
    user-role Test_Guest-guest-logon
    access-list session global-sacl
    access-list session apprf-test_guest-guest-logon-sacl
    access-list session logon-control
    access-list session captiveportal
    access-list session v6-logon-control
    access-list session captiveportal6
    yes, dns work for users, and normal resolv domain names after connect (and before and after succes manual login)
  • 4.  RE: Don't work CPPM redirect to external portal
    MVP EXPERT
    Posted Mar 20, 2019 10:45 AM
    Is the client attempting to be re-directed from a HTTP or HTTPS page? Are
    you still using the default certificate?
  • 5.  RE: Don't work CPPM redirect to external portal
    Posted Mar 20, 2019 10:55 AM
    No, client no attempting to be re-directed from a HTTP or HTTPS page.
    Yes, I using the default certificate.
    If the user did not manually go to the portal page, then when he tries to go to any web-site, he see "It is impossible to open the page", as a result, in nslookup - the domain resolves in this moment.
    Does anyone have the correct config to use an external portal? I would be very grateful for the example. I'm afraid the wizard creates something wrong. The truth about manual documentation was with the same result: (
    But here is the most interesting thing - I have one more controller, the same one, and everything was created correctly on it, everything works fine. Already from there I’m going to transfer settings through the cli - but again with the same result - the auto-redirect after connect to wifi does not work :(
    I'm at a dead end :( Help pls...
  • 6.  RE: Don't work CPPM redirect to external portal
    Posted Mar 20, 2019 11:08 AM
    I think to make a full reset for this device, maybe some bug is incurable now. But I have 60 named access points there. Is it possible to restore the points and their names after a full reset and format, or will I have to manually fill them all in again?
  • 7.  RE: Don't work CPPM redirect to external portal
    MVP EXPERT
    Posted Mar 20, 2019 11:13 AM
    I would not factory reset the device as this should work as expected. I would strongly recommend replacing the default cert as this will break your Captive Portal regardless if the client is trying to re-direct from the HTTPS page.
    https://community.arubanetworks.com/t5/Controller-Based-WLANs/ArubaOS-Default-Certificate-Revocation-FAQ-Controllers/ta-p/275809
    If you look at the datapath session do you see the client attempting to access the Captive Portal automatically via a re-direct?
  • 8.  RE: Don't work CPPM redirect to external portal
    Posted Mar 20, 2019 11:21 AM
    Thanks, I will try tomorrow, I will collect still information and I will write by result here
  • 9.  RE: Don't work CPPM redirect to external portal
    Posted Mar 20, 2019 12:05 PM
    Clearpass has the option to test the login pages and you usually copy the url and paste it to the captive-portal profile on your controller, So, does your radius has something like that? Maybe it is something in the url itself that do not let the browser to redirect automatically.
    Also make sure that you're allowing http/https to your radius server, dns and dhcp services under your guest role.
  • 10.  RE: Don't work CPPM redirect to external portal
    Posted Mar 21, 2019 04:07 AM
    It's magic, but today all work is fine after full reboot all APs and this controller.
    Thanks for answers All!
