Network Management
Dose Airwave Suppourt CISCO VSS/VPC.
  • 1.  Dose Airwave Suppourt CISCO VSS/VPC.
    Posted May 06, 2020 04:39 AM
    please I need to know if the below devices supported by the airwave server, I tried to add C9500X using SNMPv2 but airwave discover only one Device.
    2* cisco C9500-40X (Version 16.09.02) connected together using VSS.
    2* cisco C3172T (nxos.7.0.3.I7.7.bin) connected together using VPC.
  • 2.  RE: Dose Airwave Suppourt CISCO VSS/VPC.
    Posted May 06, 2020 08:57 AM
    In latest 8.2.11.0 code we have support till 9400CX, does both switches are in stack, are you adding commander?
  • 3.  RE: Dose Airwave Suppourt CISCO VSS/VPC.
    Posted May 07, 2020 01:46 AM
    Hi Pavan,
    both switches in stack currently, yes the commander.
  • 4.  RE: Dose Airwave Suppourt CISCO VSS/VPC.
    Posted May 07, 2020 05:25 AM
    Check logs in system > status page for more details, if you are not seeing any entry in this log and device in new device list then you may need to file feature. currently we have support till 9400 in latest 8.2.11.0 code.
    DiscoveryOK/var/log/discovery
    Discovery Event Existing-AP CacherOK/var/log/discovery_event_cacher
  • 5.  RE: Dose Airwave Suppourt CISCO VSS/VPC.
    Posted May 14, 2020 05:17 AM
    TAC Answer: Cisco 9500 model is not yet fully supported. As it is not yet validated you can add these devices as Universal devices while adding them to Airwave instead of cisco devices.
    Adding devices as Universal devices should show them up on Airwave but with limited features.
  • 6.  RE: Dose Airwave Suppourt CISCO VSS/VPC.
    Posted May 18, 2020 06:23 AM
    I haven't tested that i do have standard switches running pos with vpc on the 5ks side directly connected by 10gb works fine so i know the vpc to standard po will work fine for you McDVOICE
  • 7.  RE: Dose Airwave Suppourt CISCO VSS/VPC.
    Posted May 19, 2020 05:15 AM
    I know about conf sync, and sometimes I wish I didn't. To be fair, it is a whole lot better than it used to be. Early versions were buggy, and sometimes would get into a state where the two boxes were synchronised but they thought they were inconsistent.
