dot1x client stuck in Initial Role
  • 1.  dot1x client stuck in Initial Role
    Posted Mar 08, 2020 10:07 PM
    I have a few dot1x clients stuck in initial roles (State SM_INITIAL) that wont authenticate.
    They have initially authenticated but had a timeout on their last 802.1x login which generates a Deny Access Profile ( as per wired policy enforcement guide ).
    However, once that profile is applied they get stuck in the initial role and no further authentication processing (either dot1x or mac-auth);
    sw01# sh port-access clients 9 detailed
    Port Access Client Status Detail
    Client Base Details :
    Port : 9 Authentication Type : 802.1x
    Client Status : initial role Session Time : 480637 seconds
    Client name : host/CLIENTX01 Session Timeout : 0 seconds
    MAC Address : d067e5-1a3d82
    IP : 10.11.10.44
    Auth Order : Not Set
    Auth Priority : Not Set
    LMA Fallback : Disabled
    Downloaded user roles are preceded by *
    User Role Information
    Type : predefined
    Reauthentication Period (seconds) : 0
    Cached Reauth Period (seconds) : 0
    Logoff Period (seconds) : 300
    Untagged VLAN : 300
    Tagged VLANs : 200
    Captive Portal Profile :
    Policy : denyall_104112101032097114117098097032098105108108
    policy user "denyall_104112101032097114117098097032098105108108"
    10 class ipv4 "classipv4_104112101032097114117098097032098105108108" action deny
    20 class ipv6 "classipv6_104112101032097114117098097032098105108108" action deny
    exit
    10 match ip 0.0.0.0 255.255.255.255 0.0.0.0 255.255.255.255
    exit
    10 match ip ::/0 ::/0
    exit
    Tunnelednode Server Redirect : Disabled
    Secondary Role Name :
    Device Attributes : Disabled
    Interface configuration is fairly standard as per wired policy enforcement guide;
    interface 23
    name "dot1x"
    tagged vlan 200
    untagged vlan 300
    aaa port-access authenticator
    aaa port-access authenticator tx-period 10
    aaa port-access authenticator supplicant-timeout 10
    aaa port-access authenticator client-limit 3
    aaa port-access supplicant
    aaa port-access mac-based
    aaa port-access mac-based addr-limit 2
    The only solution is to bounce the port which then triggers authentication again.
  • 2.  RE: dot1x client stuck in Initial Role
    MVP
    Posted Apr 10, 2020 12:34 PM
    Can you try setting a re-auth req number as well? I'm surprised that after a single timeout, the device did not try again to authenticate.
    The other you could try is set the session timeout to 0, so when the port status changes (down/up) it will authenticate the device, but while it's still connected, it will just maintain it's status.
    We don't use Aruba switches, we have Cisco, but we use an auth-fail VLAN assignment of our quarantine VLAN, I've seen some devices have timeouts in the past, mostly when PC is locked or asleep, so we changed the session timeout to 0 and it now keeps them online unless their switch port bounces. Seemed to help in our scenario.
  • 3.  RE: dot1x client stuck in Initial Role
    Posted Apr 10, 2020 01:12 PM
    What version of code are you using ?
    Is the device performing 802.1X and Mac auth at the same time?
  • 4.  RE: dot1x client stuck in Initial Role
    Posted Apr 10, 2020 01:59 PM
    Do you have reauth-period timer configured on the ports?
  • 5.  RE: dot1x client stuck in Initial Role
    MVP
    Posted Apr 10, 2020 02:06 PM
    The line we use on our ports is "authentication timer reauthenticate server" and in the RADIUS response, we return a session timeout of 0 (meaning never).
    In our case, we saw no need to reauthenticate a machine that was already known to be valid.
