Dot1x + Known MAC authentication
This thread has been viewed 24 times
  • 1.  Dot1x + Known MAC authentication
    Posted Dec 07, 2022 11:02 AM
    I have installed a Clearpass cluster and what to make a service that checks if a username in the AD is a member of "Printers group" + its MAC address has to be "known" in order to authenticate it.
    Here is my enforcement for that service (rule #2):
    The "PRINTERuser" is a role in a role mapping attached to this service.
    I have checked - and it worked fine only with the PRINTERuser - which means the problem can't be there.
    Here is the role mapping attached as well:
    Do I miss something?
    Any ideas ?
    Best regards,
    Alon Haber
  • 2.  RE: Dot1x + Known MAC authentication
    MVP EXPERT
    Posted Dec 07, 2022 02:19 PM
    Hi Alon,
    Maybe you can give some more information. Check the access-tracker authorization attributes if it contains memberof "IT".
    Marcel Koedijk | MVP Expert 2022 | ACEP | ACMP | ACCP | ACDP | Ekahau ECSE | Not an HPE Employee | Opinions are my own
  • 3.  RE: Dot1x + Known MAC authentication
    Posted Dec 08, 2022 06:04 AM
    Thank you for replying.
    My problem is not with the ITuser.
    is with the PRINTERuser.
    From the perspective of member of "Printers group" - I have no problem,
    But when I am adding the Endpoint status = known - I am having a problem and it does not match rule# 2 (here in the picture above).
    Maybe I have related to the wrong parameter in here:
    Best regards,
    Alon Haber
  • 4.  RE: Dot1x + Known MAC authentication
    Posted Dec 08, 2022 06:37 AM
    Hi Alon
    I think you need to change to check for status Known instead of known, as it's case sensitive. Another option is to change the condition to EQUALS_IGNORE_CASE
    Best Regards
    Jonas Hammarbäck
    ACCX #1335, ACMP, ACDP, ACNSP, ACEP, ACSA
    Aranya AB
