Wired Intelligent Edge
Doubt about rolling upgrade step (from ArubaOS-CX 10.01 to 10.02)
  • 1.  Doubt about rolling upgrade step (from ArubaOS-CX 10.01 to 10.02)
    MVP GURU
    Posted Feb 14, 2019 05:44 PM
    Scenario: Rolling upgrade from ArubaOS-CX 10.01 (say 10.01.0030) to 10.02 (say 10.020010).
    Two doubts reading ArubaOS-CX 10.02.0010 in preparation to a scheduled upgrade:
    Why the no keepalive command is needed to be executed on both VSX members as a preparatory step before booting new software version? ...is it still necessary if only VSX LAGs are used to downlink hosts/devices?
    How can the ISL Keepalive be established automatically again after the upgrade (as written on ArubaOS-CX VSX Guide for 10.02: "Keepalive is restored later when the VSX configuration is applied" Step 3 page 8) if it is then requested to save configuration after the issue of no keepalive command (Step 5 page 9)? ...there isn't a following step on the described rolling upgrade procedure where the keepalive command is required to be reapplied to reestabilish the ISL Keepalive again.
    Am I wrong? Am I misunderstanding listed rolling upgrade preliminary steps?
    Side note: just an example, I really don't understand the "VSX LAG secondary switch" terminology used in VSX Guide...shouldn't it simply be "VSX secondary switch"?
  • 2.  RE: Doubt about rolling upgrade step (from ArubaOS-CX 10.01 to 10.02)
    Posted Feb 15, 2019 04:56 AM
    Hi Davide,
    I suspect that this was kept from requirement of first version 10.0.
    I performed many VSX upgrades without removing keepalive and it does not impact failover time. I'll check internally about this sepcific point in the release note.
  • 3.  RE: Doubt about rolling upgrade step (from ArubaOS-CX 10.01 to 10.02)
    MVP GURU
    Posted Feb 15, 2019 06:11 AM
    Hi Vincent, I did that too on every update performed since first ArubaOS-CX 10.01.0001 of July 2018 (once I first deployed our VSX)...without any issue!
    That's why reading about the no keepalive step was a little bit worrying.
    Interestingly ArubaOS-CX 10.02.0001 or ArubaOS-CX 10.02.0010 Release Notes didn't mention about the no keepalive step.
  • 4.  RE: Doubt about rolling upgrade step (from ArubaOS-CX 10.01 to 10.02)
    Posted Feb 25, 2019 10:10 AM
    I got confirmation that this point was specific for 10.0 to 10.1 migration. (no mclag keepalive). The documentation will reflect this correction soon. Thanks !
  • 5.  RE: Doubt about rolling upgrade step (from ArubaOS-CX 10.01 to 10.02)
    MVP GURU
    Posted Feb 25, 2019 12:05 PM
    That's good. Thank you Vincent.
