Comware
  • 1.  doubt - Removing Bridge aggregation
    Posted Jul 23, 2014 12:45 PM
    Hi guys
    I would like to know what it happens to the link between two switches if I remove a bridge aggregation, using :
    interface ten-giga 7/0/1
        undo port link-aggregation group
    interface ten giga 7/0/2
    undo interface bridge-aggregation 1
    Theses interfaces are trunk , connecting 2 switches.
    If I remove that bridge-aggregation, will the link stay UP?
    theses interfaces will remain trunk and the link won't miss any packets?
    In fact, I want to remove the bridge and I dont know the consequences :(
    Thank you
    William
    #bridgeaggregation
  • 2.  RE: doubt - Removing Bridge aggregation
    Posted Jul 23, 2014 07:25 PM
    If the two interfaces connecting to another device are no longer in a link-aggregation group, then spanning-tree will have to block one of the links.
  • 3.  RE: doubt - Removing Bridge aggregation
    Posted Jul 24, 2014 11:54 AM
    I got it.
    I was thinking that STP would not work once I had not configured the interfaces, only the bridge.
    However, once STP is enabled, it will operate for the whole switch.
    Thanks!
