I have a similar issue where the AP has been removed from the MM but the entry is still present on the MD controller
The clear gab-db command was carried out on the MM but you are not allowed to do this on the MD controller - you get this alert 'This command must be run on the master.'
Can anyone assist with this ?
Many Thanks
David Hurley
Original Message:
Sent: May 17, 2020 05:40 PM
Subject: Down AP and removing it from Controller
Yes, you can delete the defect AP with the command "clear gap-db wired-mac". In 6.x there is no GUI command for that, this feature is recent add in the latest ArubaOS 8.6 version.
If your new AP is "up" in the default ap-group, just re-provision it with the correct name and ap-group.
