Down grading OS
  • 1.  Down grading OS
    Posted Jul 30, 2013 03:15 PM
    I have a client running an older firmware version. (6.2.1.0-3.3.0.0_38115) They do not want to upgrade since we just got there network stable last week.
    They had an IAP go down.  I was going to lean them one of my spare IAP for coverage at there office.  I am at a hirer firmware.(6.2.1.0-3.3.0.2_38733.
    How do I install the older firmware for the AP?  Or will the IAP be downgraded when it conects to the other network?
  • 2.  RE: Down grading OS
    Posted Jul 30, 2013 03:19 PM
    GO to the support.arubanetworks.com site and download the IAP OS you want to install and then connect to the IAP and from the Maintenance tab > Firmware you can upload the OS
  • 3.  RE: Down grading OS
    Posted Jul 30, 2013 03:28 PM
    It will downgrade to match the rest of the cluster.
  • 4.  RE: Down grading OS
    Posted Jul 30, 2013 03:33 PM
    New IAPs joining a cluster should upgrade/downgrade per the virtual controller upon joining.  If you feel more comfortable you can downgrade ahead of time per vfabian's instructions.
    EDIT:
    I am getting slow on the keyboard ..... Seth covered it...
  • 5.  RE: Down grading OS
    Posted Jul 30, 2013 04:34 PM
    Thanks to all who provided information.  Just for the fun of it.  I am going to downgrade via the image file.  I have not done it before.
