Aruba Instant Wi-Fi: Meet the controllerless Wi-Fi solution that's easy to set-up, is loaded with security and smarts, and won't break your budget.
Downgrade Aruba AP 505
  • 1.  Downgrade Aruba AP 505
    Posted Nov 18, 2022 12:34 PM
    Hi everyone,
    I would like to downgrade some Aruba AP 505 from the 8.7 to the 8.6 version. Is there any proper way to do it? I've been looking for the procedure but I can't find anything related to it.
    thanks in advance!
  • 2.  RE: Downgrade Aruba AP 505
    MVP GURU
    Posted Nov 18, 2022 12:38 PM
    Just push the lower version the same way you would an upgrade. No extra upgrade/downgrade steps need to happen.
    Dustin Burns
    ACCX 1271| ACMX 509| ACSP | ACDA | MVP Guru 2022
  • 3.  RE: Downgrade Aruba AP 505
    Posted Nov 24, 2022 12:09 PM
    Hi AM87,
    As we already know that AP-500 Series fall under the Gemini ♊ Category. So you can downgrade directly from Gemini-8.7.X.XX to Gemini-8.6.X.XX's conservative releases without leap paths as @DB86 Mentioned.
    You may choose the final conservative release : ArubaInstant_Gemini_8.6.0.19_85031
