downgrade IAP 225/315
  • 1.  downgrade IAP 225/315
    Posted Apr 18, 2017 03:39 AM
    I've a cluster with 2 IAP-225 and 2 IAP-315 running firmware 6.5.1.0-4.3.1.2
    I would like to downgrade the APs to 6.4.4.8-4.2.4.6.
    I tried to upgrade all together, and even just the 315  - but I alwasy get image verification failed. If I only have the 315 in the cluster and I try the uploading local file (instead of tftp), it says "invalid image file".
    I was able to downgrade to 6.5.0.0-4.3.0.0, however, any firmware below that - the verification fails.
    The log is empty.
  • 2.  RE: downgrade IAP 225/315
    MVP EXPERT
    Posted Apr 18, 2017 03:45 AM
    Hey,  according to the datasheet the minimum supported firmware for the IAP315 is Aruba InstantOS 4.3.0.0, so you will not be able to downgrade below that.
  • 3.  RE: downgrade IAP 225/315
    Posted Apr 18, 2017 04:19 AM
    True!  good catch.
    That means I can't have an instant cluster with a combination of 315 and 105.
    However, stupid HP site, shows the lower version as available/compatible for the 315:
    JW813A Aruba IAP-315 (US) Instant 2x/4x 11ac AP
    Software: ArubaInstant_Hercules_6.4.4.8-4.2.4.6_58505 (Current ReleasesSelect another software release
    Aruba Instant code for IAP-324/325
    Supported products:
    • JW796A ARUBA AP-314 FIPS/TAA 2X2/4X4 11AC AP
    • JW324A ARUBA IAP-325 (JP) INSTANT 4X4:4 11AC AP
    • JW317A ARUBA IAP-324 (IL) INSTANT 4X4:4 11AC AP
    • JW805A ARUBA IAP-314 (RW) INSTANT 2X/4X 11AC AP
    • JW322A ARUBA IAP-324 (US) FIPS/TAA INSTANT AP
    • JY690A ARUBA IAP-325 (WW) INSTANT AP
    • JW325A ARUBA IAP-325 (RW) INSTANT 4X4:4 11AC AP
    • JW809A ARUBA IAP-315 (IL) INSTANT 2X/4X 11AC AP
    • JW327A ARUBA IAP-325 (US) INSTANT 4X4:4 11AC AP
    • JW806A ARUBA IAP-314 (RW) FIPS/TAA INSTANT AP
    • JW321A ARUBA IAP-324 (US) INSTANT 4X4:4 11AC AP
    • JW811A ARUBA IAP-315 (RW) INSTANT 2X/4X 11AC AP
    • JW186A ARUBA AP-325 DUAL 4X4:4 802.11AC AP
    • JW808A ARUBA IAP-314 (US) FIPS/TAA INSTANT AP
    • JW812A ARUBA IAP-315 (RW) FIPS/TAA INSTANT AP
    • JW797A ARUBA AP-315 DUAL 2X2/4X4 802.11AC AP
    • JW326A ARUBA IAP-325 (RW) FIPS/TAA INSTANT AP
    • JW319A ARUBA IAP-324 (RW) INSTANT 4X4:4 11AC AP
    • JW807A ARUBA IAP-314 (US) INSTANT 2X/4X 11AC AP
    • JW318A ARUBA IAP-324 (JP) INSTANT 4X4:4 11AC AP
    • JW813A ARUBA IAP-315 (US) INSTANT 2X/4X 11AC AP
    • JW814A ARUBA IAP-315 (US) FIPS/TAA INSTANT AP
    • JW798A ARUBA AP-315 FIPS/TAA 2X2/4X4 11AC AP
    • JW184A ARUBA AP-324 DUAL 4X4:4 802.11AC AP
    • JW187A ARUBA AP-325 FIPS/TAA 4X4:4 802.11AC AP
    • JW804A ARUBA IAP-314 (JP) INSTANT 2X/4X 11AC AP
    • JW323A ARUBA IAP-325 (IL) INSTANT 4X4:4 11AC AP
    • JW803A ARUBA IAP-314 (IL) INSTANT 2X/4X 11AC AP
    • JW795A ARUBA AP-314 DUAL 2X2/4X4 802.11AC AP
    • JY745A ARUBA IAP-324 (JP) FIPS/TAA INSTANT AP
    • JY746A ARUBA IAP-325 (JP) FIPS/TAA INSTANT AP
    • JW320A ARUBA IAP-324 (RW) FIPS/TAA INSTANT AP
    • JW328A ARUBA IAP-325 (US) FIPS/TAA INSTANT AP
    • JW185A ARUBA AP-324 FIPS/TAA 4X4:4 802.11AC AP
    • JW810A ARUBA IAP-315 (JP) INSTANT 2X/4X 11AC AP
  • 4.  RE: downgrade IAP 225/315
    MVP EXPERT
    Posted Apr 18, 2017 05:07 AM
    Oh yeah I see what you mean! Maybe log a ticket with TAC and get the final answer.
  • 5.  RE: downgrade IAP 225/315
    Posted May 06, 2017 11:04 AM
    Hi Adi,
    315's are only supported from 4.3.0.0.
    I will get this corrected on the site.
    I would like to confirm you are referring to HPE My Networking Portal.
