Comware
download firmware HP A5120-48G-PoE+ EI
This thread has been viewed 26 times
  • 1.  download firmware HP A5120-48G-PoE+ EI
    Posted Feb 14, 2017 08:22 AM
    Friends,  I need to upgrade the firmware of my environment HP A5120-48G-PoE+ EI  from 2220P02 to  R2222P01. I´m trying to find the location in order to download this firmware and complete my task.  Could you please provide me the directions in orde to download the firmware or the link?
    My best regards
    Adriano Porcaro
    #firmwareupdate
  • 2.  RE: download firmware HP A5120-48G-PoE+ EI
    MVP GURU
    Posted Feb 14, 2017 04:31 PM
    Hi Adriano,
    Go here, then select "Get drivers, software and firmware" link and you will be able to see the list of HPE 5120 EI Switch Series here, your model's Firmware (JG237A) should be found here (HPE A5120EI-CMW520-R2222P01 Release Notes PDF document is here).
    Always start your searches at HPE Support portal using your Product Number (JG237A) or Switch family name (HPE 5120 EI)...and - for sure - you will be able to find what you're looking for.
  • 3.  RE: download firmware HP A5120-48G-PoE+ EI
    Posted Feb 22, 2017 02:34 PM
    Thanks for the help!!!!  Solved!
  • 4.  RE: download firmware HP A5120-48G-PoE+ EI
    Posted Feb 17, 2017 09:11 AM
    You should bookmark this link (https://h10145.www1.hpe.com/downloads/ProductsList.aspx), as you can find every switch's upgrade files here with the product number.
  • 5.  RE: download firmware HP A5120-48G-PoE+ EI
    Posted Nov 24, 2023 10:17 AM
    Hi! I'm updating this post because I need the firmware + bootrom for this switch and I can't find it in the links mentioned above.
    Can anyone help me?
  • 6.  RE: download firmware HP A5120-48G-PoE+ EI
    Posted Nov 24, 2023 02:03 PM
    Good luck unless you have a hpe/aruba support company account... :)
  • 7.  RE: download firmware HP A5120-48G-PoE+ EI
    Posted Nov 25, 2023 12:53 AM
    Don't you have access to Aruba Support Portal (ASP) ?
    If not, go there : https://asp.arubanetworks.com
    and register.
    Then, as parnassus said, you shall access all switches' firmwares and documents.
    Frederic MEUNIER
  • 8.  RE: download firmware HP A5120-48G-PoE+ EI
    Posted Nov 29, 2023 10:20 PM
    Thank you! I found the firmware on the portal you mentioned. It's kinda messy all those versions of the same hardware switch.
    To help anyone who needs this and came up here, the link below points to the last version of the firmware for this model.
    HPE Aruba Networking | Enterprise (arubanetworks.com)
