Downloadable Users Roles - Profile for Access Points
This thread has been viewed 24 times
  • 1.  Downloadable Users Roles - Profile for Access Points
    Posted Aug 16, 2019 09:03 PM
    I'm having an issue whereby I'm sending downloadable user roles from ClearPass to an Aruba Switch (2930F - v16.09.003). Specifically, I've created a profile for an access point to boot on a colorless port. I can see that the AP works as intended in a statically assigned port and the AP will boot on the untagged VLAN but I'm unable to connect to and SSID that's using the tagged VLAN on the switch.
    In this example the AP should boot on VLAN 100 and clients should associate to VLAN 101. Yet it seems the switch is not handling the tagged port traffic correctly.
    Is there anything special that needs to be done to get DUR working for an access point regarding the tagged vlans?
    Aruba-Lab-SW1# show port-access clients 6 detailed
     Port Access Client Status Detail
      Client Base Details :
       Port            : 6                     Authentication Type : mac-based
       Client Status   : authenticated         Session Time        : 603 seconds
       Client Name     : 20a6cdc05a98          Session Timeout     : 28800 seconds
       MAC Address     : 20a6cd-c05a98
       IP              : 172.16.100.10
       Auth Order      : Not Set
       Auth Priority   : Not Set
       LMA Fallback    : Disabled
    Downloaded user roles are preceded by *
     User Role Information
       Type                              : downloaded
       Reauthentication Period (seconds) : 28800
       Cached Reauth Period (seconds)    : 0
       Logoff Period (seconds)           : 300
       Untagged VLAN                     : 100
       Tagged VLANs                      : 101
       Captive Portal Profile            :
       Policy                            :
       Tunnelednode Server Redirect      : Disabled
       Secondary Role Name               :
       Device Attributes                 : Disabled
    The role I'm sending from ClearPass is the following:
    aaa authorization user-role name "DUR-Access-Point"
    reauth-period 28800
    vlan-name "LAB-MGMT"
    vlan-name-tagged "LAB-Corp"
    exit
  • 2.  RE: Downloadable Users Roles - Profile for Access Points
    Posted Aug 16, 2019 09:08 PM
    I also recognize that what I'm attempting to do may not be possible if the switch is attempting to authenticate every individual MAC address that connects to a given port. Or if there's a way to disable this, that would be helpful/great.
  • 3.  RE: Downloadable Users Roles - Profile for Access Points
    Posted Aug 17, 2019 07:06 AM
    You have to send back the port mode attribute introduced with WC.16.08. This is available on ClearPass in the standard downloadable user role configuration since 6.8. It is explained in the Access Security Guide of the Switch:
    http://h22208.www2.hpe.com/eginfolib/Aruba/16.09/5200-5908/index.html#GUID-C6553916-956F-4830-BA98-A127FC63677D.html
    Also check the attached picture.
  • 4.  RE: Downloadable Users Roles - Profile for Access Points
    Posted Aug 17, 2019 11:15 AM
    Is this an IAP?
    Thank you
    Victor Fabian
    Pardon typos sent from Mobile
  • 5.  RE: Downloadable Users Roles - Profile for Access Points
    Posted Aug 17, 2019 06:57 PM
    It is an IAP!
    I tried sending back HPE-Port-Dot1x-Port-Mode and HPE-Port-Macauth-Client-Limit and the switch complained.
  • 6.  RE: Downloadable Users Roles - Profile for Access Points
    Posted Aug 17, 2019 09:17 PM
    Thanks Holger! This worked perfectly!
    reauth-period 28800
    device
    port-mode
    exit
    exit
