Comware
DRNI vs IRF
  • 1.  DRNI vs IRF
    MVP
    Posted Aug 09, 2023 02:11 AM
    Can someone give a brief about HPE DRNI? Is it similar to Aruba VSX stacking? I'm in a dilemma whether to use DRNI or IRF for a Data Center core switches with HPE FlexFabric 12000 series switches.
    Which is better?
  • 2.  RE: DRNI vs IRF
    Posted Mar 18, 2024 10:42 AM
    Yes, I think it's similar to Aruba VSX.
    But can you use DRNI commands on HPE FlexFabric 12000 series switches? Now I'm stuck with the problem of not being able to use the DRNI command on my HPE 12000 series.
