Drop Connection in specific Area
  • 1.  Drop Connection in specific Area
    Posted Apr 10, 2017 07:00 AM
  • 2.  RE: Drop Connection in specific Area
    Posted Apr 10, 2017 07:04 AM
    Do you have a diagram of where the access points are?
    Do you have a picture of any of the access points?
    Are you using RF plan to see the coverage of the access points?
    You probably know that the AP60 is a single-band access point that probably only operates on the 2.4ghz band.  It could be difficult to make a 2.4ghz only band AP work with high density.
    Band steering would not be useful, since the AP only offers a single band at a time.
  • 3.  RE: Drop Connection in specific Area
    Posted Apr 21, 2017 05:03 AM
  • 4.  RE: Drop Connection in specific Area
    Posted Apr 21, 2017 06:43 AM
    I don't have much information to understand what could be happening here...
