DRT Download Error IAP 325
  • 1.  DRT Download Error IAP 325
    Posted Jun 11, 2020 02:39 AM
    I can see the notification that there is a new DRT. When I go to download it automatically there is an error to download. I have looked at the logs and shows malformed url. Any ideas to fix as seems Aruba issue.
  • 2.  RE: DRT Download Error IAP 325
    Posted Jun 12, 2020 05:46 AM
    I see the same on my AP version 8.6.0.4.
    Can you download the DRT from the Aruba Support Portal manually as a workaround, if this is urgent for you?
    Did you open a support case already for this?
    I have raised a ticket with Aruba support. It appears that the latest DRT can't be downloaded for some reason, older versions are fine, they are looking into this now.
  • 3.  RE: DRT Download Error IAP 325
    Posted Jun 17, 2020 04:45 AM
    This has been resolved, I can download the DRT again from the WebUI.
