Dual Authentication in Aruba
  • 1.  Dual Authentication in Aruba
    Posted Mar 10, 2017 05:53 AM
    Is there any possibility for dual authentication in Aruba Network?
    I mean if I want to authenticate from MAC address and also from Password ? please tell me possibilty.
  • 2.  RE: Dual Authentication in Aruba
    Posted Mar 10, 2017 05:59 AM
    Do you mean MAC auth + PSK?
    Yes, that is possible.
  • 3.  RE: Dual Authentication in Aruba
    Posted Mar 10, 2017 06:00 AM
    how? please tell steps
  • 4.  RE: Dual Authentication in Aruba
    Posted Mar 10, 2017 06:08 AM
    Are you trying to do dual authenticatoin using CPPM or Aruba controllers?
    Pavan
  • 5.  RE: Dual Authentication in Aruba
    Posted Mar 10, 2017 06:10 AM
    no. just normal authentication
    format ad-cd-ef-gh-ij-kl
  • 6.  RE: Dual Authentication in Aruba
    Posted Mar 10, 2017 06:21 AM
    Here is a sample config that you can copy-paste. Just replace the word "CRYSTAL". Add the allowed mac addresses to the internal-db in the specified format.
    ip access-list session CRYSTAL-MAC-DENY
    any any any deny
    user-role CRYSTAL-MAC-DENY
    session-acl CRYSTAL-MAC-DENY
    ip access-list session CRYSTAL-MAC-ALLOW
    any any any permit
    user-role CRYSTAL-MAC-ALLOW
    session-acl CRYSTAL-MAC-ALLOW
    aaa authentication mac CRYSTAL-MAC
    case lower
    delimiter none
    aaa authentication dot1x CRYSTAL-MAC
    aaa server-group "CRYSTAL-MAC"
    auth-server Internal
    aaa profile "CRYSTAL-MAC"
    initial-role CRYSTAL-MAC-DENY
    mac-default-role CRYSTAL-MAC-ALLOW
    authentication-mac CRYSTAL-MAC
    mac-server-group CRYSTAL-MAC
    authentication-dot1x "CRYSTAL-MAC"
    wlan ht-ssid-profile "CRYSTAL-MAC"
    wlan ssid-profile "CRYSTAL-MAC"
    essid "CRYSTAL-MAC"
    wpa-passphrase password@12345
    opmode wpa2-psk-aes
    wlan virtual-ap "CRYSTAL-MAC"
    aaa-profile "CRYSTAL-MAC"
  • 7.  RE: Dual Authentication in Aruba
    Posted Mar 11, 2017 12:49 AM
    Dear Rajaguru Vincent
    I am using aruba controller no CPPM.
    Please suggest
  • 8.  RE: Dual Authentication in Aruba
    Posted Mar 11, 2017 11:09 AM
    That config does not require CPPM.
  • 9.  RE: Dual Authentication in Aruba
    Posted Mar 13, 2017 09:00 AM
    Just wondering why do you want to do this?
    Just use some kind of strong authentication like EAP TLS
    MAc authentication add almost no security because its easy to clone it, it does not scale  past a handful of devices becuase is difficult to maintain a list of mac addreses.
    Just my 2 cents :)
    Cheers
    Carlos
