Dual Band Aruba 318 and AP-ANT-45 connection
  • 1.  Dual Band Aruba 318 and AP-ANT-45 connection
    Posted Nov 06, 2019 03:42 PM
    I am evaluating to deploy a Dual Band Aruba 318 Access Point altogether with an external antenna Dual Band AP-ANT-45. Nevertheless, how to connect these two elements is not described in any document I have seen so far.
    The Access Point 318 has 6 antenna connectors, 4 for 5GHz and 2 for 2.4GHz.  The AP-ANT-45 has 4 RP-SMA terminals.
    I am guessing that we can connect these elements as follows:
    • 2 RP-SMA terminals of the antenna to 2 5GHz connectors of the Access Point
    • 2 RP-SMA terminals of the antenna to 2 2.4GHz connector of the Access Point
    • 2 5GHz connectors of the Access Point will not be used
    The last, is just my guess.  I would like your support confirming or rejecting it. If anyone has relevant information to properly deploy these two elements together, please provide it.
  • 2.  RE: Dual Band Aruba 318 and AP-ANT-45 connection
    Posted Nov 08, 2019 09:59 AM
    With the AP-318 having two separate radios and antenna chains, you will need 2 antennas, one per radio. The AP-ANT-45 is a dual-band antenna and works great for Access Points that have built-in diplexers to get the signal of both radios to a single connector.
    You should connect one AP-ANT-45 with 4 wires to the 4 connectors of the 5 GHz radio. Then you need another antenna for the 2.4GHz radio with 2, 3 or 4 elements of which you only connect 2 wires (H and V) to the 2.4 GHz radio of the AP-318.
    Please also check the Aruba 318 Access Point Ordering Guide, which mentions an antenna selection for radio 0 (5GHz) and another for radio 1 (2.4GHz).
    Please consult your Aruba partner or local Aruba SE to find out what is the best AP solution for your situation.
