Wired Intelligent Edge
Dual factor Auth with FortiAuth
This thread has been viewed 27 times
  • 1.  Dual factor Auth with FortiAuth
    Posted Apr 28, 2021 09:02 AM
    Hello ,
    We have a customer who has Aruba 2900 series and 16.x AOS version
    They want to Integrate The wired switch with FortiAuthenticator which provides the token ( Same as RSA token)
    Goal is to have MFA configured on Aruba Switch . The Fortiauthenticator is also acting as Radius Server .
    Can someone give a confimation that Aruba Switch Support MFA ( AD User Password + Token)  and provide the required commands to do it
    AG
  • 2.  RE: Dual factor Auth with FortiAuth
    MVP GURU
    Posted Apr 28, 2021 03:22 PM
    Hi AG,
    it is for manage the switch ?
    ACEP / ACMX #107 / ACDX #1281
  • 3.  RE: Dual factor Auth with FortiAuth
    Posted Apr 28, 2021 04:24 PM
    Yes it is to manage the switch​
    AG
  • 4.  RE: Dual factor Auth with FortiAuth
    Posted Apr 29, 2021 12:59 AM
    Hello , anyone please?
    I didn't find any document which says Aruba switch supports token based authentication.
    It says certificate based or username password .
    Kindly reply
    AG
  • 5.  RE: Dual factor Auth with FortiAuth
    Posted Apr 29, 2021 02:19 AM
    Hi.
    We are also looking into Fortiauthenticator (FAC) as our 2fa.
    what kind of 2fa are you looking at? push or token? cause it works on push on mobil, mayby you can type password + token key but i haven't testet that one yet.
    On push its only a radius to the FAC and then the FAC sends a push before validatin the username and password, mayby ask your local fortinet SE? iv got a meeting with my fortinet SE next week, then i'll ask the same thing.
    Morten Johannsen
  • 6.  RE: Dual factor Auth with FortiAuth
    Posted Apr 29, 2021 02:37 AM
    We are looking for forti token based authentication for Aruba switches .
    We have tested MFA with other integration like FW etc which works.
    For aruba switches , I can't see if MFA is supported based on token.
    I checked for fortinet SE and they asked to check with Aruba SE:)
    AG
  • 7.  RE: Dual factor Auth with FortiAuth
    MVP GURU
    Posted May 01, 2021 03:20 PM
    Good question, like morjo say, you can use password and token when ask the password, it will be work
