Dual Homing IAP-325-US
  • 1.  Dual Homing IAP-325-US
    Posted Feb 02, 2017 09:28 PM
    Hey all,
    I'm building out a network for a remote site that will have no IT presence (at least not within easy driving distance), so I'm trying to make it as resilient as possible. Right now I'm looking at the IAP-325-US as the AP model and the 2540 as the switch.
    I believe that you can dual home APs with a controller-based setup, but can I dual home the two ethernet ports on the IAP-325-US to two separate switches when using the Instant platform?
    Thanks in advance!
  • 2.  RE: Dual Homing IAP-325-US
    Posted Feb 03, 2017 08:35 AM
    It appears you can. Check out this post.
  • 3.  RE: Dual Homing IAP-325-US
    Posted Feb 06, 2017 10:58 AM
    Perfect! Thank you very much James.
