Hi ,
I am trying to intergate Duo with CPPM for Dual factor authntication using captive portal . Everything goes fine starting from connecting to the SSID and putting username password in the captive portal page.However if get error "Content is block due to certificate is not trused" while redirecting to Duo API page.
This is a test enveronment and i am using all self signed certficates in CPPM. There is a way to bypass the certificate block masage or how can i fix it without having CA certficate .
Is there something i am missing while configuring Duo in CPPM?
MD
