duplicate a skin in Clearpass
This thread has been viewed 26 times
  • 1.  duplicate a skin in Clearpass
    Posted Dec 08, 2016 03:26 PM
    Hi community,
    is it possible to clone or duplicate a skin under plugins?
  • 2.  RE: duplicate a skin in Clearpass
    Posted Dec 08, 2016 03:31 PM
    You'll need to open a TAC case and they can add additional built-in skins.
  • 3.  RE: duplicate a skin in Clearpass
    Posted Dec 09, 2016 01:40 PM
    You can have multiple iterations of "Galleria Skin" or "Custom Skin 1" -- but not of an official/tailored customer-specific skin.
    What are you trying to do specifically? Most of the time, customizations can be done in one skin, but using dynamic varaibles (e.g. based on APGroups)...
  • 4.  RE: duplicate a skin in Clearpass
    Posted Oct 04, 2018 05:06 AM
    can you show me how to clone or duplicate galeria skin sir ?
  • 5.  RE: duplicate a skin in Clearpass
    Posted May 09, 2019 06:27 AM
    same question here, how to clone the galleria skin
  • 6.  RE: duplicate a skin in Clearpass
    Posted May 09, 2019 07:04 AM
    We can customize skin but can not duplicate default Galleria skins in Guest!
  • 7.  RE: duplicate a skin in Clearpass
    Posted May 09, 2019 07:31 AM
    Open a TAC case. They can add additional Galleria skins for you.
  • 8.  RE: duplicate a skin in Clearpass
    Posted Jul 23, 2019 12:05 PM
    I'm not sure if this is what the OP wants, but I'd just like to know that any changes I make to the Galleria 2 skin through the plugin manager will not be overwritten by a future update.  (Specifically I want to change the number of picture and the transition time in the rotation.)
  • 9.  RE: duplicate a skin in Clearpass
    Posted Jul 24, 2019 04:27 AM
    Are you talking about the ClearPass firmware update?
    If yes, then changes to the Skins plugins will not be overwritten after the software update.
  • 10.  RE: duplicate a skin in Clearpass
    Posted Jul 24, 2019 05:48 AM
    Yes, that was it. Thanks.
  • 11.  RE: duplicate a skin in Clearpass
    Posted Apr 23, 2021 10:56 AM
    Unfortunately this was not the case. We recently upgraded from 6.7.x to 6.9x and lost the Galleria Skins customizations we were using. Waiting on TAC now to see if we can pull this from a backup.
  • 12.  RE: duplicate a skin in Clearpass
    Posted Apr 24, 2021 11:18 PM
    @su_A_ve
    Change the Skin Plugin version and check ​​
    Vigneshwar Sivakumar
