Duplicated or even triplicated IP on IAP
  • 1.  Duplicated or even triplicated IP on IAP
    Posted Sep 28, 2016 09:47 AM
    Hi Community,
    Did you ever come across this?
    Thanks all,
    Myky
  • 2.  RE: Duplicated or even triplicated IP on IAP
    Posted Sep 28, 2016 10:45 AM
    Are there two DHCP servers in your environment?
  • 3.  RE: Duplicated or even triplicated IP on IAP
    Posted Sep 28, 2016 10:57 AM
    Hello Colin,
    We do have only one DHCP server for this particular SSID/VLAN.
    But unfortunately, we do not manage it. Do you think it is because of two servers in place or due to server error.
    Thx,
    Myky
  • 4.  RE: Duplicated or even triplicated IP on IAP
    Posted Sep 28, 2016 11:10 AM
    I do not know of any reason why you would have different mac addresses assigned to the same ip address, unless you had two DHCP servers...
  • 5.  RE: Duplicated or even triplicated IP on IAP
    Posted Sep 28, 2016 11:47 AM
    Thanks Colin for sharing your thoughts. We are currently investigation this. Will get back here with any further updates.
  • 6.  RE: Duplicated or even triplicated IP on IAP
    Posted Sep 29, 2016 08:13 AM
    Two issues here:
    Our DHCP server IP address pool is exhausted. IAP had default inactivity timeout for 24 hours, now changed for 12. Also adding another VLAN for additional DHCP address range.
  • 7.  RE: Duplicated or even triplicated IP on IAP
    Posted Sep 29, 2016 11:51 AM
    What is your current dhcp lease time?  Change it to something like 4 hours and adjust the inactivity to match or lower.
