DUR not downloaded | ssl error
This thread has been viewed 30 times
  • 1.  DUR not downloaded | ssl error
    Posted Apr 07, 2021 03:13 AM
    Hi all,
    I am working on getting UPT to work on my 2930F & Clearpass.
    Currently, I got stuck with downloading my user role.
    The authentication of my test-client works fine and the following radius-response is sent to the switch.
    Nevertheless, when running "show user-role downloaded" no user role is listed and no tunnel to the controller is established.
    When debugging SSL security I discovered that my certificate is marked as expired. My certificate is the root certificate from my windows testing pki.
    As of my thinking the certificate should be valid, because it expires in 2521:
    Is there another problem or is my root certificate the real problem?
    Best regards
    Michael
    Michael
    Michael
  • 2.  RE: DUR not downloaded | ssl error
    MVP GURU
    Posted Apr 07, 2021 07:31 AM
    Did you create the Clearpass login user for the switch to login to clearpass and perform an HTTP GET to retrieve the role information? Also, your switch needs to trust the certificate chain from Clearpass.
    Dustin Burns
  • 3.  RE: DUR not downloaded | ssl error
    Posted Apr 07, 2021 08:23 AM
    You can't use the root certificate itself for ClearPass, instead, issue a certificate from that root for your ClearPass. Role downloads require the server certificate to be issued by another CA, the root itself is self-signed (by definition).
    The expiration time of 500 years might be an issue as well, but first, make sure you are not using the root CA itself as ClearPass server certificate.
  • 4.  RE: DUR not downloaded | ssl error
    Posted Apr 08, 2021 09:29 AM
    My error was that I had the switch listed within Clearpass with a wrong IP address...
    Michael
