i'm in the process of pushing out DURs across our estate
All switches ( standalone or multiple switch stack) running WC.16.11.13
I've done 4 sites multiple switches / stacks using same defined DURs and they've all worked.
At 1 site I have a 5 switch stack and. am getting an error saying
05619 DCA SR2-CMDR ... deauthenticating client downloaded user role .... is not valid Flash file copy error.
but the DUR is valid, theyre the same ones used everywhere else. Also the command to delete a DUR doesnt work
and there are no errors in the logs .
However, show user-role down det does show the DUR contents and they are valid
Any thoughts ?
Am progressing. the "have you switched it off and on ?" avenue :-)
A
