Wired Intelligent Edge
  • 1.  DUR Role Parsing Failed
    Posted Jul 28, 2024 08:51 AM
    The environment is:
    R8Q70A 6200M 48G CL4 PoE 4SFP+ Sw  ML.10.13.1031
    CPPM 6.11.8.258602 with latest patches (20240430-radius-crash-fix-cphf-141 & 20240506-dur-enf-vlan-cphf-143)
    I am trying to push a basic DUR (simplified to only a VLAN assignment for now), but the switch is giving an error message:
    Type  : clearpass
    Status: Failed, Role Parsing Failed
    If I debug portaccess all, i see the following:
    Parsing the XML for the cprole DUR2-3061-2 failed
    I have an older 6.10 CPPM cluster waiting to be decommissioned, and if I point the switch to that with a matching policy everything works as expected.
    Is there any type of known DUR issue with CPPM 6.11 and CX 10.13.1031?
    I already have a support case open in parallel to this.
  • 2.  RE: DUR Role Parsing Failed
    Posted Jul 30, 2024 05:37 AM
    I'm not aware of such issues. Let's see what TAC comes up with. Please keep us updated.
  • 3.  RE: DUR Role Parsing Failed
    Posted Aug 12, 2024 08:35 AM
    I vaguely remembered that some xml parsing issue was presented in ACSX course and after checking the course material it indeed was: "When the XML result does not contain the correct commands, the "parsing xml failed" message will be shown". In the given example issue was caused by wrong credentials:
    Roy Lillqvist | ACSX #1421 | CCIE(RS) #38597
  • 4.  RE: DUR Role Parsing Failed
    Posted Aug 12, 2024 08:41 AM
    I fixed the issue, and believe it was likely mismatched credentials.
    Those commands would have been awesome at the time to confirm it was the credentials.      I'll bookmark them for sure.
  • 5.  RE: DUR Role Parsing Failed
    Posted Apr 29, 2025 06:09 AM
    Role Parsing Failed refers to incorrect Clearpass admin role that downloads DUR roles from CPPM Server to the switch.
    You need to be careful especially when using templates as passwords are not cleartext once you save it in the template, and if you copy paste from other tenants you may copy stars instead of actual password.
