Dynamic ACL Roles via Radius / FreeRadius , Instant AP ?
  • 1.  Dynamic ACL Roles via Radius / FreeRadius , Instant AP ?
    Posted Mar 30, 2015 02:33 PM
    Hi
    customer inquiry , dynamic ACL role when authenticating via radius, anyone built this already, e.g. with Instant APs ?  customer would like to modify acl's on Radius server, not on Aruba Instant or Controller ,
    Talked with some SE's they pointed to Radius VSA , but dont have further details, need some binary answer "yes this is working properly" .
    thanks
    ben
  • 2.  RE: Dynamic ACL Roles via Radius / FreeRadius , Instant AP ?
    Posted Mar 30, 2015 02:35 PM
    Downloadable roles/ACLs are currently only available in controllers.
  • 3.  RE: Dynamic ACL Roles via Radius / FreeRadius , Instant AP ?
    Posted Mar 31, 2015 06:04 AM
    sounds good, you ever built this , or is there some homebrew or some basic step by step information what/where to config , e.g. if doing a PoC for customer and let him test the aruba solution with controller/AP based.
    any homebrew documentation avail ?
  • 4.  RE: Dynamic ACL Roles via Radius / FreeRadius , Instant AP ?
    Posted Oct 23, 2015 01:33 PM
    Hi!
    But what about preconfigured roles on Instant? Can I send role name in ACCEPT message from the Radius and get it applied on the access point?
  • 5.  RE: Dynamic ACL Roles via Radius / FreeRadius , Instant AP ?
    Posted Oct 23, 2015 02:03 PM
    You need to import the Aruba radius dictionary and use the Aruba-User-Role VSA to send the value.
    You can also use filter-ID but then you have to map everything on the VC.
    Tim
