Wired Intelligent Edge
Dynamic Port Configuration
  • 1.  Dynamic Port Configuration
    Posted Jul 29, 2020 01:13 PM
    Hi, I have a few Aruba JL320A 2930M switches which currently run POE Telephones.
    I'm now looking to add some UniFi APs and would like to use the device-identity, device-profile and device-profile device-type commands to automatically set the correct vlans for the ports.
    Does anyone know what the correct oui would be for UniFi APs and if I can set several tagged vlans under the device profile command?
    Any guidance would be appreciated.
    #2930M
    #2930M
