Wired Intelligent Edge
Dynamic Segmentation Aruba CX - Do I need a Controller/Central?
  • 1.  Dynamic Segmentation Aruba CX - Do I need a Controller/Central?
    Posted 11 days ago
    Hi Guys,
    With Aruba CX switches, do I need a controller/Central to make this work?
    Champ
  • 2.  RE: Dynamic Segmentation Aruba CX - Do I need a Controller/Central?
    Posted 10 days ago
    you need a controller/gateway only if you want to statically of dynamically build overlay tunnels from your CX switches.
    but if you want the traffic from the authenticated users to be bridged then you dont need a Conytroller or Aruba Central.
  • 3.  RE: Dynamic Segmentation Aruba CX - Do I need a Controller/Central?
    Posted 10 days ago
    Hi.
    I just want user authenticating to be able to use Roles through services declared on clearpass.
    Do CX switches natively support pef licensing?
    Just trying to work out how authentication dot1x actually gets passed to clearpass for further processing.
  • 4.  RE: Dynamic Segmentation Aruba CX - Do I need a Controller/Central?
    Posted 9 days ago
    You are mixing different things. Let me break it down for you
    1) There is no PEF licensing in CX switches. PEF licensing is available in Wireless Controllers (aka Gateways)
    2) Dynamic Segmentation in a nutshell is authenticating users and assigning them network segments (Vlans/Roles). This is done as a standard Dot1x configuration. Switches are configured with AAA Radius Dot1x configuration on global and port level. Once the device connects to the port, the dot1x process initiates. Credentials are then forwarded to ClearPass for authentication, once authentication succeeds, the port is configured with returned attributes such as Roles, Vlans etc.
  • 5.  RE: Dynamic Segmentation Aruba CX - Do I need a Controller/Central?
    Posted 5 days ago
    Thanks@Ronin101 for clarifying.
    That makes sesnse now.
