E Flag on Aruba 109 RAP
  • 1.  E Flag on Aruba 109 RAP
    Posted Dec 08, 2014 04:13 AM
    Hey Guys,
    I have a RAP 109 that has the E Flag ( Domain Regulatrory mis-match )
    Does anyone know why this happens? Or how i can get rid of the E flag ?
    It was working last week with no issues, now all of a sudden it is not working and has the E flag when i look it up on the controller.
    Any help MUCH appreciated.
  • 2.  RE: E Flag on Aruba 109 RAP
    Posted Dec 08, 2014 05:03 AM
    When it was an IAP, what regulatory domain was it?  Now that it is a RAP what regulatory domain is t now?
    What version of ArubaOS is the controller running?
  • 3.  RE: E Flag on Aruba 109 RAP
    Posted Dec 08, 2014 05:18 AM
    Software version on the controller -
    ArubaOS (MODEL: Aruba7220), Version 6.3.1.5
    Regulatory domain info
    Country:IN
    Model:Aruba7220
    Hardware:Unrestricted
  • 4.  RE: E Flag on Aruba 109 RAP
    Posted Dec 08, 2014 05:31 AM
    chewbacca,
    Does the IAP-109 have a sticker with the model number on the back?  What does it say?
  • 5.  RE: E Flag on Aruba 109 RAP
    Posted Dec 08, 2014 06:46 AM
    There is a sticker on the back, the only thing relating to a model number is just that it says RAP-109
  • 6.  RE: E Flag on Aruba 109 RAP
    Posted Dec 08, 2014 10:16 AM
    Chewbacca,
    When you first brought it up in instant mode, did you set the regulatory domain to IN?
  • 7.  RE: E Flag on Aruba 109 RAP
    Posted Dec 09, 2014 04:42 AM
    Yes, i would have set it to IN as thats where the RAP is located.
    Should it be changed to US?
  • 8.  RE: E Flag on Aruba 109 RAP
    Posted Dec 09, 2014 07:31 AM
    Chewbacca,
    It should absolutely work.  You might want to open a support case so that they can look at your logs.
  • 9.  RE: E Flag on Aruba 109 RAP
    Posted Dec 09, 2014 08:43 AM
    There can one reason, check the ap's regulatory domain profile that you have mapped,
    I just replicated your issue and here is the output,
    (Aruba3200) #show ap database
    AP Database
    Name Group AP Type IP Address Status Flags Switch IP Standby IP
    24:de:c6:c3:96:21 TestLab 105 172.16.10.150 Up 1h:50m:11s 172.16.0.254 0.0.0.0
    24:de:c6:c6:36:e4 default 135 172.16.10.4 Down 172.16.0.254 0.0.0.0
    9c:1c:12:cb:12:02 TestGP RAP-109 10.1.1.12 Up 14m:39s Rc2E 172.16.0.254 0.0.0.0
    I believe issue is also same as highlighted.
    Put the following command and check the country code that you have selected.
    in this example I have choosen country code(regulatory-domain-profile) as US and the controller countrycode as IN.
    if your case also same please change it to IN.
    (Aruba3200) #show ap regulatory-domain-profile default
    Regulatory Domain profile "default"
    Parameter Value
    Country Code US
    Valid 802.11g channel 1
    Valid 802.11g channel 6
    Valid 802.11g channel 11
    (Aruba3200) #show country
    Country:IN
    Model:Aruba3200
    Hope this will help you on fixing the issue :)
    Please feel free to comeback for any furhter assistance.
    Cheers,
    Venu Puduchery.
