EAI 9 Address family for hostname not support
  • 1.  EAI 9 Address family for hostname not support
    Posted Mar 03, 2014 11:06 AM
    We just tried to install a fresh copy of AMP 7.7.9 and encounted the following problem during the initial setup wizard. All STEPs are a per-usual and valid IPv4 addresses are defined, but STEP 7 fails with the following:
    STEP 7 : Generating AMP's SSL certificate.
         Does AMP have a valid DNS name on your network (y/n)? y
         Enter AMP's fully qualified domain name: amp.company.ac.uk
         Generating SSL certifciate for amp.company.ac.uk
    [Mon Mar 03 15:24:50 2014] [crit] (EAI 9)Address famility for hostname not support
    ed: alloc_listener: failed to set up sockaddr for 127.90.0.1
    Syntax error on line 165 of /etc/httpd/conf/httpd.conf:
    Listen setup failed
    starting...
    The setup wizard continues but  at the end of it does not apply any of the IP configuration. Has anyone encounted this before?
    Many thanks,
    Paul
  • 2.  RE: EAI 9 Address family for hostname not support
    Posted Mar 04, 2014 12:29 AM
    I would open a TAC case on that to get some additional troubleshooting started.
